跳转到主内容
加入维修社区 - 创建账户
这是第三代 Apple iPad 4G 版本的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储空间可选。于 2012 年 3 月发布。可通过型号 A1430 (GSM, AT&T) 或 A1403 (CDMA, Verizon) 进行识别。维修时需要使用热风并小心撬开。
iTunes error -1. Maybe Hardware defect?
Hi,
As anyone had seen the error -1 (unknow error)? Any suggestion for solution?
I had read, that is an hardware problem on Nand Flash, maybe right?
The iPad 3 (A1430) wont turn on after an update.
When i disassemble it, i had checked that the Main Board Flex Interconnector is broken.
I had resolder the terminals and buyed an new flex, but i have my doubts that this is the problem. I'm Wainting the Flex Arrive.
Sorry if some English errors :D
Best Regards
Paulo Silva
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
-1 is usually the baseband
由完成的
Hi,
I will try to Reflow it and check if it works...
Many Thanks
由完成的
添加一条评论
1个答案
was this resolved?? as im having the same issue
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paulo Silva 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 16
总计 710
