ghost touch while charging
got a weird problem,phone works perfectly fine with no issues but whenever charge the device, my friend is experiencing ghost touch and severe lags. Unable to control the touch and it works fine when its not under charging. Tried different charger and still the same problem. Anyone experiencing the same problem?
9条评论
Has screen been replaced before? Some aftermarket screens show signs of this.
由 Ben 完成的 分享
no, almost new phone, i searched and found quite a few people encountered this problem and no solution
由 Kaye 完成的 分享
I have seen this issue a few times, and having only ever been able to tie this issue to the phone receiving too much charge due to an issue some where down the line relating to power. A better charger has rectified this in other phone models but replacing the screen has never solved it for me. It wont effect the phone overall, you just cannot use your phone whilst charging .
由 David Hynes 完成的 分享
Then it's a phone design issue. The digitizer circuit is not insulated enough to avoid interference with the charging circuit while charging the phone.
In result it interferes with the touch screen because of the power going through the phone.
As touch screens are capacitive, they detect the change of current from your fingers. So if you put a charging cable that has power going through on top of the screen it will interfere.
I hope that makes sense.
由 Ben 完成的 分享
you're right, thanks!
由 Kaye 完成的 分享
显示更多的4条评论
