跳转到主内容
加入维修社区 - 创建账户
Polaroid 制造的平板电脑的维修指南和支持。
Hard reset my tablet
How do i hard reset with no buttons on it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
7条评论
My tablet is not open
由完成的 分享
Hi
Restart my tablet and tablet is start but not operate his menu
由完成的 分享
Polaroid PMID701C. The tablet will not factory reset. I held the reset button and it turns off then back on with a locked screen.
由完成的 分享
How to flash it
由完成的 分享
My tablet is not opening
由完成的 分享
显示更多的2条评论
添加一条评论
3个答案
已选择的解决方案
Hi,
Is there a 'reset' pin hole in the back by any chance?
If so, gently insert the end of an opened paper clip into the hole and push in until you feel a button being pushed. Hold it there for about 10 seconds and then release. Your tablet should reset and start again.
If there is no reset pin hole, what is the model number of your tablet?
这个答案有帮助吗?
得分 10
5条评论:
I tried the reset button and it's still showing an ! Mark on the battery
由完成的 分享
@Alicia Matier ,
Try just charging the battery for a while. Do not attempt to turn on the tablet.
If is still shows the ! mark when you first plug in the charger, leave it charging for at least 1-2 hours and check if it has kick started back into charging again.
Sometimes when the battery has been depleted too far you can't even start the tablet with the charger connected.
If it does kick back into life by starting to charge allow it to fully charge before attempting to turn on the tablet.
If it does turn on after this you may have to "nurse" the tablet by not allowing the battery level to fall too far (this may happen very quickly) before recharging it as the battery may be beginning to fail and needs to be replaced.
Even rechargeable batteries have a lifespan
由完成的 分享
I tried to do reset but when i turns power back on and it just kept off itself every time i tried to turns power back on. Is there anything I can get it fixed or anything solutions?
由完成的 分享
Hi @Cody Adamson
What happens if you just connect the charger to the tablet? Does it show that it is charging?
If so let it fully charge and then try turning it on with the charger switched on and connected.
What is the model number of the tablet?
由完成的 分享
The Polaroid Tablet I got is Model P700 or so. It doesn't show a charge icon, or turn on or let me reset when I press the tiny buttons in.
Help?
由完成的 分享
添加一条评论
OK I figured out how to reset this machine.
  1. Turn off the tablet.
  2. Turn the tablet back on while holding the power and the back button.
  3. After the machine starts release the power button but continue to hold the back button.
  4. Once you get the android screen use the back button to go down to reset #3.
  5. Acknowledge the reset by hitting the power button.
  6. After it says all data is rest hit #1 to restart tablet and it will be back at factory settings.
这个答案有帮助吗?
得分 1
添加一条评论
Hi @ Tom Tracey,
Here’s an image of the tablet showing the location of the “reset” switch, taken from the user manual.
Gently insert a straightened paper clip until you feel the switch operate, then hold it operated for about 10 seconds and then remove the paperclip.
Be sure to insert it into the correct hole, as it is right next to the hole for the microphone and you don’t want to damage the microphone by inserting the paperclip into it instead
这个答案有帮助吗?
得分 0
6条评论:
This dont work it keeps asking for the pattern password
由完成的 分享
I'm getting the same thing. The reset button is not working.
由完成的 分享
Yes the reset button is not working
由完成的 分享
I've done everything that people say to do and it's still not working, can anyone help us.
it's a Polaroid Android table
PMID1000D
由完成的 分享
The pattern lock screen is on and I can't get into it I need to reset it so I can unlock the screen if possible.
由完成的 分享
显示更多的1条评论
添加一条评论
添加你的答案
melisakellar36 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 56
总计 18,685
