跳转到主内容
加入维修社区 - 创建账户
Nikon D5200 是一款采用 F 卡口的单反相机,配备 2410 万像素 DX 格式 CMOS 图像传感器。D5200 的最高分辨率为 6000x4000,并支持 1080p 视频录制。
Memory card is locked
Suddenly I started getting an error message that that memory card is locked (it's not). Same message no matter what card I put in. Will not reset--format memory care is grayed out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Slide the white button on the memory card -- amazing works like a charm
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
Have you unlocked the memory card itself?
Try to formate the memory card on a laptop and then try to use it
Update (09/09/2016)
Did you format using the correct SD card formatting tool? You can it downloaded from sdcard.org
Or you can try to do a hard reset on your camera.
1. Remove battery, Memory card, and lens for about 30 seconds
2. Reinsert just the lens and the battery, power the camera on
ensure you are using an approved card: Answer Title: Approved SD cards for D5200 Answer Link:https://support.nikonusa.com/app/answers...
3. The camera settings can be restored to default values by holding the "Menu" and "i" buttons down together for more than two seconds
(these buttons are marked by a green dot). The information display turns off briefly while settings are reset.
4. Hit the menu button and select custom setting menu
5. Select "F" for controls and then "F4" labels " Slot empty release lock"
6. Highlight "Enable release"
7. Test camera with no card/ then reinsert the card and try again
这个答案有帮助吗?
得分 2
1条评论:
Formatted in the computer just fine, but same message.
由完成的 分享
添加一条评论
添加你的答案
doylecozadd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 7,650
