跳转到主内容
Daisy Model 10 Carbine 400 shot BB repeating air rifle. Maximum velocity: 350 FPS. Maximum shooting distance: 195 yards. Lever cocking action. .177 cal. BBs. Part No. 300664-000
5 个问题 查看全部
BB gun will $!^& but not fire,doesn't seem to compress spring
Daisy Red Ryder B.B gun model 1938B
so my son,daughter and i were enjoy some pinking when my daughter says the bb gun wont fire. put it on safe and took if from her, I manually cocked the lever but if felt like there was no resistance, took gun off safe aimed and attempted to fire, nothing happened, tried the safety a few times to ensure it wasn't stuck.. that isn't the problem..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
apparently there is some sort of language filter here, I will assume you guys/gals know what I am trying to say about the condition of the gun.
完成的
It won't pump up ;-)
完成的
sure, there is another word but..
完成的
i,m not involved in any of this latest bb s--- ,m eighty yrs old and still like shotting cans and targets
完成的
添加一条评论
2个答案
已选择的解决方案
bpjefferson365 and @mayer, my thought is more related to the plunger and the lever not connecting. If the lever does not connect with the plunger then there will be no resistance. Even if the spring would be broken, it would still have some resistance since it can not move anywhere. See if this diagram will help a bit. Here is a really good tutorial, even so the model is different. It should still apply to your Daisy as well.
这个答案有帮助吗?
得分 3
3条评论:
It may be c*cked now.
完成的
Nah, the mechanism is not working for that
完成的
I have a old flip down barrel BB gun and it's missing the little round thing that connects to the fireing pin so it does flip back down
完成的
添加一条评论
Try checking out the firing mechanism : Daisy Model 10 Carbine Firing Mechanism Replacement
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
bpjefferson365 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 50
总计 30,985
