跳转到主内容
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
I have error code 32
I have error code 32. My tv will not even turn on just the indicator light flashing yellow for the lamp.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
hizeada what model is your TV and what have you checked?
完成的
添加一条评论
1个答案
最有帮助的答案
Hello, hizeada. Error code 32 corresponds with an open lamp cover. If your lamp cover is in fact closed, then chances are the lamp cover is either not installed properly or the lamp door switch simply isn't working. You can try to troubleshoot this by removing both the lamp cover and the entire rear cover. First, check the operation of the switch. You want to ensure that the long lever part of the switch is not broken and is in the correct position to make contact with the lamp cover when everything is reassembled. If the switch seems to be in good condition, go ahead and reinstall the rear cover and lamp cover and check to see if you are still getting the same error.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
hizeada 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,027
