跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
F H, error code at startup?
F H error code? Whats it mean? Washer stops.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
vsouki2000 FH code (Water Inlet Problem--no water or insufficient water supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power.Check the following:
open water faucets completely
check the screens at inlet hose connection to washer to make sure they are not clogged. Make sure that the water hoses are not kinked. Plug in washer or reconnect power. Re-select cycle and press START.
It can also be caused by a bad drain pump motor as well as a failed flow meter. I suggest that you download the service instructions from the bottom of this page and run the diagnostic cycle. Then let us know what you found.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
vsouki2000 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,496
