How can I retrieve the memory from my broken iPhone 4s?
My iPhone 4s was destroyed by my estranged father and I'm pretty sure he must've hit it with a sledge hammer because it's in pieces now. I desperately need the pictures off of my phone, they were really important to me. Is there a anyway I can extract the memory from my broken iPhone or where I should take it to get the pictures back. Any info will help, thanks.
4条评论
I added some pictures, I hope that helps. I'm not sure which pieces are what but it is pretty bent out of shape :(
由 Rose Lillie 完成的
thanks for the pics :) i have to agree with old turkey on this one it looks like a bit of a mess but with some LUCK and some patience the logic board might sill be able to be extracted as a whole. if you could place them logic board in a different shell it might just work !!! but the odds are against you from what i can see but i ve seen worse and it still worked ;)
由 Reboot Gozo 完成的
actually ... on a bit of a closer look ... i think i can see a gash in the logic board, just under the battery flap... right where the sim card was ... looks like the sim tray caused damage as well ... i have to be realistic with you ... i think this is a goner :(
由 Reboot Gozo 完成的
So is the sim card the piece that holds the memory/pictures?
由 Rose Lillie 完成的
