跳转到主内容
加入维修社区 - 创建账户
Fairphone 的第二代产品,由同名社会企业制造。发布于 2015 年 12 月。 型号:FP2-XCVR
Via USB to Ethernet using an. Adapter
I want to access the Internet via an USB to Ethernet Adapter, for example my Adapter which uses the Davicom DM9621A controller. It works at my tablet out of the box. Not with the Fairphone2. Any solutions? Does some other Adapter work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
8条评论:
Hi,
Check if you have the following setting in your phone. If so enable it. It may not be there. I have 3 different tablets - don't ask - only one has this setting and it is the only one that works with a USB to Ethernet adapter.
Go to Settings > Wireless and Networks > more, tap to enter and see if Ethernet is an option. If so tap to enter and tap on Use Ethernet.
由完成的
Hi jayeff,
that is the way how I got the adapter working with my tablet. Unfortunately the Fairphone2 does not offer this setting. Maybe this means that none of such adapters will work. I'll ask the fairphone manufacturer. Thanx!
由完成的
Does the fairphone have otg, like does it work with a usb drive or mouse
由完成的
Hi Ethan,
Thanx for your answer.
the file manager shows that /storage/usbotg is available, and I tried out and all of the following worked perfectly:
- connection to PC via usbotg
- external hard drive
- external SD card via a universal card reader
- mouse
(besides my question: thanx for giving me the idea to test a mouse at the Fairphone2! I liked it and I'll continue to use a mouse, at least when I'm sitting at my home desk ... )
But still my two USB to Ethernet adapters do not work (Davicom DM9621A, ASIX AX88772B) ...
由完成的
Hi @basche_ralf ,
If you're interested, there are some apps available to help you do what you want. Unfortunately they all depend on your phone being rooted. Just "Google" Ethernet to USB android app. Here are just a couple of links.
https://play.google.com/store/apps/detai...
http://forum.xda-developers.com/showthre...
由完成的
显示更多的3条评论
添加一条评论
1个答案
Hi,
September 1 by jayeff
Hi jayeff,
September 2 by Ralf
September 2 by Ethan Chow
Hi Ethan,
- mouse
September 3 by Ralf
Hi @basche_ralf ,
September 4 by jayeff
这个答案有帮助吗?
得分 0
1条评论:
Hi,
1st to Sylvain Mignot: you did not enter new text, only repeated the previous comment thread ???
Today I tried to continue with my issue.
Unfortunately I updated the OS to 1.7.0 (successfully) , but: now the root access disappeared and the description how to root the device seems not to work anymore: I'm not able to update the boot loader.
sudo adb reboot bootloader
results in this message on PC:
error: device unauthorized. Please check the confirmation dialog on your device.
But on the Fairphone no confirmation dialog appears.
Any ideas?
由完成的
添加一条评论
添加你的答案
Ralf 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 1,046
