跳转到主内容
加入维修社区 - 创建账户
这是一款由 SodaStream 制造的家用饮料机。该设备旨在通过机器本身和糖浆,方便你在家中制作碳酸饮料。此特定型号最初生产于 2007 年左右。
Leaks when making soda
when making soda, the gasket located where the bottle screws in is old and hard.
the soda leaks down the bottle and onto the counter.
i cannot find a replacement gasket on line??
cujim
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I used Sugru, which you can buy on Amazon or Target and made my own gasket. The object is to not make it so thick just about a string of 1/4 inch Surgru around the inside, screw the bottle in just enough to make a slight screw impression and then take the bottle out and let it dry for 8-10 hours.
You've now made your own gasket with a rubber material that will last a couple of years.
这个答案有帮助吗?
得分 1
2条评论:
Thank You! I will try it
由完成的
FYI - I found so many soda streams in garage sails and/or on the stoop in the street of Brooklyn ..
由完成的
添加一条评论
iFixit doesn't carry them; I'd check with Sodastream to see if they sell a replacement. You might have some luck in taking the gasket to a hardware store and see if they have a similar gasket.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JIM Nichols 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 46
总计 2,024
