跳转到主内容
How to replace keyboard in a MacBook Pro 13" early 2011?
The backspace key of my keyboard got lost and can not be replaced separately.
How can i change the whole keyboard? Why aren t there any repair instructions on Ifixit for this case?
Would be happy for some instructions!
Thank you!
Maike
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you only lost the key cap element you can replace that alone! Here is one source for the part: The Book Yard - Key Caps for MacBook Pro Unibody.
If you have more damage than just replacing the external key cap parts then you have two choices here. The first is replacing the entire upper case. Here is the IFIXIT guide: MacBook Pro 13" Unibody Early 2011 Upper Case Replacement while still a bit of work it is the quickest way. Here is the needed part: MacBook Pro 13" Unibody (Early 2011/Late 2011/Mid 2012) Upper Case Yes its expensive! but its a lot less work.
OK, what the next option? You'll still need to follow the same IFIXIT guide to take the upper case off. Then, you'll remove the keyboard and replace it. Here is a bunch of eBay listings for the part: Replacement MacBook Pro Keyboards. Yes, it's a lot less, but it's also a lot of work as you'll need to either pop out 50+ snap rivets or screws or a combo of the two. Here's a vid on how its done: Macbook Pro 13" A1278 Keyboard Repair and Replacing. Good Luck!
Replace an upper case assembly compatible with the model A1278 Early 2011 to Mid 2012 MacBook Pro 13 inch Unibody laptop.图片
产品
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case
$49.99
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
MacBook Pro 13" Unibody 中期 2010 键盘更换
its the same
这个答案有帮助吗?
得分 3
3条评论:
Is this guide also feasible for Mac Book Pro (A1278) early 2011?
Thanks
完成的
Yes, it's essentially the exact same.
完成的
Ohh! So I need to replace all with the aluminum uppercase and not just the keyboard...dramatic situation.
完成的
添加一条评论
添加你的答案
Maike Wehmeier 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 15,667
