跳转到主内容
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
624 个问题 查看全部
Fake Paper Jam Issue. Epson WF-7511.
I got new cartridges and after the head and nozzle cleaning I was going through the alignment process. It did no go through and started giving me a paper jam issue, I removed the tray and the back tray but there was no paper stuck anywhere. Now I have checked all of my printer and there is not even a sign of a tiny piece of paper anywhere. It still however gives me the Paper Jam error.
Can someone help me fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Have you restarting it? If you did and still have the error, it may be a blown fuse somewhere that prevents a motor from homing after an error. Have you tried searching for a service manual in the web? There should be one out there and you just have to be careful downloading stuff.
完成的
添加一条评论
2个答案
最有帮助的答案
@diabolicboy take out all of the ink cartridges and power off. After a short while turn the printer on and see if it tells you to repalce the cartridges. Then reinstall those and let us know what you get.
这个答案有帮助吗?
得分 2
1条评论:
@oldturkey03 thanks for your advice, I have tried and succeeded.
完成的
添加一条评论
Great !
Work for me on epson WF-3620 as crazy it could be.
I spent hours before to check all sensors in the paper way, and this cartridges trick allow the system to be back on track. This paper jam error message is not describing a real issue. just life !#^& off… thanks to Murphy law.
Thanks again oldturkey03
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Swapnil Kale 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 3,265
