跳转到主内容
加入维修社区 - 创建账户
2016 年 3 月发布的智能手表,支持蓝牙连接。型号:FB502SBUL
Could I replace the battery?
My Fitbit Blaze battery only lasts 10-12 hours. Is it possible to change the battery? If so where can I find a replacement battery? I know it uses a 167 mAh Lithium Ion Battery. I'm not having any luck finding one. The battery has never worked right. Fitbit sent me a replacement pebble. I'd still like to attempt to fix this one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Has anyone found any battery replacement valid for Blaze?
由完成的
I replaced my Blaze battery with this one from Amazon:
Fitbit Blaze Smartwatch Battery (Li-Pol, 3.7V, 120mAh) Replacement for Fitbit Blaze Smartwatch Battery
It's been about 2 months now and I am very happy. A charge lasts for about 3 days now.
由完成的
添加一条评论
2个答案
最有帮助的答案
Here’s where to get the battery:
Fitbit Blaze Battery
Here’s how to install it:
Fitbit Blaze 电池更换
Replace a 170 mAh battery compatible with the Fitbit Blaze smartwatch. 3.7 Volts (V).图片
产品
$19.99
这个答案有帮助吗?
得分 2
添加一条评论
You should disassembly it and then check for it's battery and then you can buy a new replacement .
这个答案有帮助吗?
得分 0
5条评论:
@acnologia how do you disassemble it and where can one get a new battery?
由完成的
There's a video on YouTube how to disassemble. The where to get the battery is the real question I've looked haven't had luck. The battery is a 167 mAh lithium ion battery. Good luck let me know if you find one.
由完成的
@oldturkey03 It's easy ,just use YouTube ,i have seen guides that do it really fast.
由完成的
Anybody know the dimensions of the battery? There are a lot of 3.7v rechargeable batteries on AliExpress
由完成的
The battery for the Fitbit Blaze is 3.2mm X 18mm X 30mm. 3.7V, If it's more than about 31 or 32 mm long, the new battery won't fit, so be careful.
由完成的
添加一条评论
添加你的答案
Tracy Kirkpatrick 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 10,330
