跳转到主内容
加入维修社区 - 创建账户
A top-loading washing machine by Fisher&Paykel.
It won't fill or pump out water
started filling and has now stopped and won't spin or pump out water. I have check water filters and water input. What could be the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
danamitchell could be a lid switch issue. If you can give us the model number, we might get more information for you.
这个答案有帮助吗?
得分 1
添加一条评论
Is the AC power on? That is, is there any indication (power light, etc) that the power is on? If not, and assuming the house circuit breaker didn't pop, you may have a blown fuse or thermal cutout. These are usually located on the control board, behind the control panel.
这个答案有帮助吗?
得分 0
添加一条评论
Had a similar problem with my mothers washing machine. These machines have a control board in them that has a microprocessor which checks external devices (eg magnetic switch , multiphase drive motor etc) at all times. Fischer and Paykel would not supply schematic here in Australia (they use "health and safety" issues to justify the reason). In my mothers situation the problem was the pump motor. . It had a few shorted turns and that was enough for the control board stop the pump motor to pump in or pump out. The thing is the problem can be intermittent.
In the USA you may even have the fault codes in the LED, here in Australia we dont have them. This is a nanny country.
这个答案有帮助吗?
得分 0
添加一条评论
I would suggest faulty RPS - soap powder ruins them ( liquid less so )
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
danamitchell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 21
总计 2,177
