Engine will not turn over
After replacing my fuel pump, my vehicle started up. But then the next day nothing. Did not turn over. When i attempt to start it i get a clicking sound.
Hi,
Have you checked your battery cables are securely connected and that the battery is not flat?
Usually a clicking sound is the starter solenoid engaging but there is not enough power for the starter motor to turn over.
这个答案有帮助吗?
You either have a bad starter,battery or alternator. Or you just have a bad ground on your fuel pump ground.
Try jumping the car and or tapping the starter with a hammer
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 874
