跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Why does iPhone 5 charge to 100% then not work when disconnected?
I suspect the battery, but not sure. It will charge to 100%, but then when disconnected it almost immediately stops working. Erratic. When left overnight without charging, it may or may not have charge remaining. Or, when left unplugged would not work until plugged in, at which point it might show 100% or 40% or whatever.
Also, could signal strength be part of the problem? Severe problem occurs in relatively remote locations or in airplane.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
this is usually signs of a bad battery. it refuses to hold a charge. i would recommend to replace it. The battery run about 20 bucks on amazon and about 10-15 bucks on ebay. When removing the battery be careful with not damaging any other parts of the phone as there are some cables laying under it. i would recommend to watch this video for the full walk through. iPhone 5 更换电池
这个答案有帮助吗?
得分 2
2条评论:
Possibly. A lower signal strength means that the phone has to work harder to receive data from the source of the signal. In this case it would be the radio towers if I'm correct.
完成的
I do agree about what Candido said.
完成的
添加一条评论
The battery can cause so much problems and thats the 1st thing i check,??
这个答案有帮助吗?
得分 2
2条评论:
Thanks, Coco, I went ahead with battery, I confirm your suggestion.
完成的
My pleasure hope you sort it out
Cheers
完成的
添加一条评论
添加你的答案
John Lozier 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 122
