跳转到主内容
Announced - 2014, November The Samsung Galaxy Core Prime (G360, G361) is powered by 1.3GHz quad-core processor, and it comes with 1GB of RAM. The phone packs 8GB of internal storage that can be expanded up to 64GB via a microSD card.
67 个问题 查看全部
Why is phone screen black?
Ok, so last night my phone was almost out of battery so left it on charge overnight. The phone was fully charged, I turned it on but about a minute after I turned it on the screen became very dark and was flickering. I can still see the screen but it is only possible under dark conditions. In normal light the screen is completely black. I have had this issue before and I fixed it by removing the battery and putting it back in, I did this and the screen went back to normal but as soon as the phone had finished turning on it went black again. I repeated this several times and got the same result. So why is this happening? My phone has been dropped and the screen is slightly cracked. My guess is that the LCD or some internal component is broken. Is there any way to fix this? My phone is a Samsung galaxy core prime, had it since November 2015, dropped it back in December. Screen issues started around February. Help would be very much appreciated. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
it seems your back light has gone out on your LCD. in some cases the back light filter IC on the motherboard fails and can produce the same type of issues. Changing the screen would be your most cost effective way of figuring it out. usually runs about $30 on Ebay for a full display. good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dalek 3125 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,627
