跳转到主内容
Improved second generation Google-branded tablet with a 7" screen.
98 个问题 查看全部
Reattach locking connector to board
While trying to repair a Nexus 7, the locking connector was removed from the Main Motherboard (sigh, it was taken off by mistake). Nothing else happened to the motherboard and the connector came off as clean. Can the connector be reattached by soldering it back on, or will a new motherboard need to be ordered?
The place where the connector went is pointed to by the tip of the screwdriver.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Your picture do not give any idea what is going on. If you want to know the answer and get help, please post detail picture of the system and how it look like. Then you can get the right help.
完成的
davidshanlay the pictures that are posted with the question look good to me. You can clearly see the solder pads where the connector was once attached to.
完成的
添加一条评论
1个答案
最有帮助的答案
@nexusnex if the connector is still in good condition it can be soldered on. Make sure that the solder pads on the board are all okay.
这个答案有帮助吗?
得分 1
6条评论:
I think they may mean just the plastic piece on the ZIF connector.
完成的
It's the whole piece that contains the plastic lock and the connector. Even though the connecter was not connected by solder - it can be soldered on?
完成的
@nexusnex post a couple of good images of the part and where it belongs with your question. That should help out a lot. Use this guide 在已经存在的问题里加入图片 for that.
If the part was not soldered to the board before, there will be no solder pads to solder it to.....
完成的
Thank you. Post edited with a photo. I suspect it can't be attached, but worth a shot. If it can't - is the only solution to get another MB?
完成的
Yep, those are solder pads. So, that connector needs to be soldered to the board. If you post a picture of the connector and the little "wires" we can probably tell you if it can be re-soldered. Anyhow for a job like that, you'll need some good skills and tools to solder it
完成的
显示更多的1条评论
添加一条评论
添加你的答案
John Boucher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 163
