跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
Samsung s5 doesnt turn on, main board problem?
I had my S5 for 1.6 years now. I have to admit that I did abuse it several times by continuing to use the phone until the battery is completely dead. Not sure if it was the culprit for my troubles.
Last week I was using my phone and the charge I remember was 70%. Then suddenly the phone turned off and I have not being able to bring it back up. I tried to plug it to the charger and keeping it there for couple of hours, didn't work. I tried putting a another battery, didn't work. The phone was never water damaged or subjected to major physical abuse. Phone does not show any indication at all ( ie no display or lights working, no vibration or sound)
Went to Samsung service center and asked them to look at it. They told me they couldn't power it on, so most probably need to spend around $300 for a repair. So, I am trying to fix it by my self now and save the money.
I think its the main board but I realized there is a power pcb as well. So I am not sure which one to replace. Can some one advice me on this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
Warnaka Gunawardena I'd start off by following the steps from the service manual for the no power option. Since there are a few different versions of the circuit board it will help if you post some good images of yours. That way we can find the components you need to measure. To post images use this guide
这个答案有帮助吗?
得分 5
1条评论:
Thanks for your solution sir. will try it out!
完成的
添加一条评论
添加你的答案
Warnaka Gunawardena 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 386
