跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
iPhone 5c won't charge after charging port replacement
I replaced the charging port and everything works fine, when I plug the lightning cable it shows charging icon right next to the battery but it doesn't charge up. Any idea? Thank you and sorry for the bad english
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
After several research, ended up buying new port, works flawless. I guess I shouldn't believe everysite claim selling OEM products. Thank you for replying
完成的
添加一条评论
2个答案
已选择的解决方案
Is there any water damage related to this phone? Have you recently replaced the battery? It sounds to me that either the new charging port is bad or the battery has gone akput. leaning more towards the new connector.
这个答案有帮助吗?
得分 1
2条评论:
No water damage, i'm fearing a bad charging port, battery hasn't been replaced, i guess it wasn't a good quality part. I'll buy a new one and let you know
完成的
Based on your other comment, it looks like a bad charging port for sure if the old part works. Try a new connector, if you are buying from ebay sort the listings by ones in north america. I find that you come across a better selection of parts. (people importing them dont want crap parts, its bad for business.)
完成的
添加一条评论
最有帮助的答案
@king_nothing that your "charging icon right" shows means your phone recognizes it. You did not tell us why you replaced the port in the first place. It is possible that this is caused by a failed charging IC. Common failure on iPhones that where charged with after market chargers. Yes, replace the battery as well, but it may need some board level repair. Check the componenets around the battery connector and the charging IC.
这个答案有帮助吗?
得分 3
2条评论:
Thanks for the reply! I replaced the port because the little home button connector that is near the speaker was broken, I'm fearing a bad charging port because I put the old one again and it charges without any issue.
完成的
"put the old one again and it charges without any issue." perfect. Good job.
完成的
添加一条评论
添加你的答案
Ricardo Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 289
