跳转到主内容
加入维修社区 - 创建账户
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Problems after getting wet
Hi. My phone got wet by a water jet. After that, I dried it. It works well except for two things. On the one hand, the capacitive button of recently apps doesn't work (it lights up but when I touch it, doesn't work). On the other hand, when I connect the phone to the PC, it isn't recognized and, when I disconnect it, the screen freezes and a black window with a little cross in the corner appears for a couple of seconds. What can I do? Is there a solution or I have to send it to the technical support? Thank you so much.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@jorgegm what you have here is a water damaged phone. You did not tell us how your dried it off and how you managed the water damage. If you have not opened it up and cleaned teh water from the inside components, you most likely are runnig into corrosion and failed components from the water damage. I would at least try to treat it like any other water damaged phone.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jorge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 363
