@pancho what is your complete serial number? This could be caused by a faulty water level switch. How full does it get? Did this just start? did it work before?
@pancho check the tube from the side of the tube that attaches to the water level switch for leaks or clogs if your washer does not fill right. If that is okay then you should consider repalcing the water level switch. Here is a great tutorial on how to test the switch
1条评论
由 oldturkey03 完成的
