跳转到主内容
Display power inverter pinout or voltage for each of 6 pins needed?
I have a broken LCD on my netbook. The LVDS cable correctly fits in the display for my iMac which was gutted when the logic board caps went bad.
I have tossed the logic board. I still have the display, the power supply and the inverter. I need to know the voltage that each pin on the inverter takes to power the back light on the iMac display directly from the power supply.
The following links may be helpful to someone who speaks French.
http://forum.macbidouille.com/index.php?...
[ http://users.skynet.be/fa835376/pas%20a%...]
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
This is from an iMac G4 is this something that you are looking at?
The inverter has 8 pins in as described below.
Blue = 11.93v
Red = 11.93v
Blk = GND
Blu = GND
N/C
Yel = .2mv
Prpl = 3.262v
Orng= no voltage detected
这个答案有帮助吗?
得分 3
2条评论:
Check this out and see if it will help you.http://dremmeljunkie.blogspot.com/2010_0...
Good luck
完成的
Also if you have the part number here you can look up the specs
http://www.jkllamps.com/index.cfm?action...
完成的
添加一条评论
添加你的答案
Shane Nelson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 6,474
