跳转到主内容
加入维修社区 - 创建账户
Pebble 于 2015 年 5 月发布的第三代智能手表。支持 iOS 和 Android 设备,电池续航时间长达 7 天。
Make pebble waterproof again
Is it possible to make pebble waterproof after tearing them down? Is there a proper glue for this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
2个答案
已选择的解决方案
Short answer: Sugru!
I was recently on holiday, swimming every day, when I noticed the internals of my Pebble Time were fogging up, which meant just one thing: the water resistance had obviously failed. I immediately took the watch off and started thinking about how I was going to repair this.
When I returned home, I pried the top of the Pebble Time off and looked at what was sealing the watch – it appeared to be some sort of rubbery self adhesive strip. I looked around the internet and thought about what I could use, but then I settled.
I cleaned off all of the adhesive rubber, and then carefully cleaned the internals of the watch, removing dust and fingerprints from the glass, before rolling out some Sugru to a very thin diameter – as close to 1mm as possible – and then laying it out around the lip on the inside of the pebble time plastic chassis.
Pressing the glass down firmly and securing it with clothes-line pegs, I then carefully trimmed off the excess Sugru that squashed out.
Leaving it overnight to cure, I tested it by going swimming the next day and, I'm happy to say, it's back to it's old water-resistant self!
这个答案有帮助吗?
得分 15
3条评论:
Thx this ist really helpful. How did sugru perform in Long Term?
完成的
It’s still waterproof 😊
完成的
brings me a smile when he still has his pebble in 2024
完成的
添加一条评论
I’ve done that by cleaning the old seal tape, and pasting RTV around the transparent cover frame, then carefully closed and tighten them overnight with laundry hanging clips.
I didn’t try to soak it in water, to test if realy watertight sealed, but the seal look tight, and RTV is used for aquariums. so believe it will withstand some water.
The drawback of this, that unlike the original tape that was designed to open the watch (and phones) by heating them with hot air gun, the RTV is also heat resistant, so opening it again for any reason could be nearly impossible (altough I believe that using a knife, carefully the cover can be pried again).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Roman Belyakovsky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 44
总计 4,553
