Why is oil leaking from the bottom of my mower
there is oil leaking from the bottom of my mower. from what I have read it is the crankshaft seal that is leaking. If so do I have to remove the engine to replace it
skiteam looks like you will have to remove the engine to get to the bottom crankcase oil seal. You will have to remove the bottom crankcase cover (116) to get the seal(118) removed.
这个答案有帮助吗?
don't know what model you are talking about but on briggs and stratton 17.5 hp the seal can be changed from the outside without removing the crankcase cover
I thought so too, that is only place leaking on mine as well after complete rebuild
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 147
总计 8,044
5条评论
skiteam what make and model is the mower and if you can give us the model and serial number off the engine.
由 oldturkey03 完成的
Craftsman 24728882 lt 1500 MTD motor 4p90hu
由 skiteam 完成的
How do I change bottom seal on a sl2000 craftmen
由 d.quimby1311973 完成的
What good to stop a leak on my craftsman riding mower
由 Stanley Walker 完成的
@stanleywalker we need a make and model for your riding mower. It will also help if you can tell us what engine it has. Can you identify what area the oil leaks from?
由 oldturkey03 完成的
