跳转到主内容
An Insignia DVD player identified by model number NS-D160A14.
Why doesn't my DVD player turn on?
Whenever I press the power button on my DVD player, it doesn't turn on, and nothing happens on the screen. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Ensure that your power supply cord is plugged in. If you are using an extension cord, ensure that the extension cord is plugged in securely. If you are using a power strip, make sure that it is plugged in and that it is switched on. If the problem persists you might need to replace your power cable.
这个答案有帮助吗?
得分 2
1条评论:
You might instinctively attempt to power the unit on only using the remote control, so be sure the remote control has fresh batteries.
完成的
添加一条评论
添加你的答案
Ian Hanken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 318
