跳转到主内容
加入维修社区 - 创建账户
一款价格亲民的 5.2 英寸 4G LTE 2016 款手机。不可拆卸电池,双 SIM 卡槽,支持最高 64GB 的 microSD 卡。
Power Button Fell Off
Had this phone for 3 months and then the power button fell off. Any ideas for replacements?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
12条评论
I have the same problem, it has never happened to me before with any other phone, I have my phone for 6 months. I think it has to do with the design. I hope there is a replacement for it.
由完成的
Anyone find a replacement for this yet? I'm also having the same issue.
由完成的
I haven't ever actually fixed a Blu phone, but I assume the parts would be a challenge. 2 things you could try: buy a broken on on ebay or wherever and loot the parts off of that or hit up alibaba. You will for sure find the parts on alibaba but shipping time can be a real pain and most sellers have minimum orders.
I'll keep this thread in mind and if I come across a supplier, I'll update.
由完成的
Can we get a picture? What do you mean by power button fall off? Like the button or the actual switch part? Can you open it up and see if the actual electrical switch that sends the signal to the board is good?
由完成的
Ethan: I've heard a bunch of Blu owners complain of this. In my mind, its like the old Motorola power buttons where its not connected to anything, its just kinda wedged in there.
But that's 100% a guess. I can't find Blu parts from any of the places I order from, including my Chinese suppliers.
由完成的
显示更多的7条评论
添加一条评论
3个答案
最有帮助的答案
Someone asked for a picture, here is goes
这个答案有帮助吗?
得分 1
添加一条评论
So I have the same issue! Although every time it has taken off I've been able to find it. It's a tiny beveled rectangular piece with rubber straps on the back that are extended a bit outwards so you can fold one side inwards after placing another into the area where the button lays at a 45 degree angle(or less). Once it has been folded you can then push down as if you are holding it for a power off until the phone either turns on or prompts your power menu options. Let go and see if this worked by performing several of your daily tasks then locking your screen. If this keeps happening you may wish to consider adding a TINY amount of superglue(or something) where the rubber meets the plastic button before placing it in as described above(obviously let it dry first!), although I have yet to try this myself and I may next time it happens!
这个答案有帮助吗?
得分 1
1条评论:
I tried this and it works
由完成的
添加一条评论
Had the same problem. I use this app to power off
https://play.google.com/store/apps/detai...
and this to power on with volume buttons.
This will brake your power buttons in a few months, but still you can use the phone until then.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kill Switch 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 17
总计 3,784
