跳转到主内容
加入维修社区 - 创建账户
2016年3月发布的4英寸iPhone,硬件规格与iPhone 6S相似。提供银色、深空灰色、金色或玫瑰金色,存储容量有16/32/64/128 GB可选。型号:A1662和A1723
iPhone SE front camera mic static.
I recently had an iPhone SE in for repair, the front camera microphone was faulty I did advise her to go back to apple with it being under warranty but she asked me to check it for her as she was unable to go back to one of their stores. I tested a new front camera flex but had the same issue (static noise) tested about 4 parts with no joy. I also have an SE and tested my front camera flex on the device and it worked fine, these parts were for the 5S but when I ordered them the description told me that it was compatible with the SE. Just wondering if anybody else is having the same issue and if they managed to repair it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
2条评论
I have ordered SE/5S front cam assemblies as well and all seems to worke except the mic. The Mic does not work properly (The siri or loudspeaker mic) I think the manufacturers haven't realized something needs to be changed for the SE part to work properly. Anyone find this part that works with the SE?
由完成的 分享
same issue, can't buy anywhere!!
由完成的 分享
添加一条评论
8个答案
最有帮助的答案
Hello and iFixit team I'm making this post so everyone can see the mistake every supplier is doing and making techs not able to solve the front camera recording or talking to Siri after replacing the front camera proximity cable.............
All the SE front camera proximity sensor everyone has been buying are 5s is not the same! The front camera will work proximity sensor will work and receiver will work but the microphone is different. Take a look at the picture 5s is on the left and SE original on the right this is why is static or mute while recording from the front camera or Siri not listening.
iFixit team tested so you can believe me.
Please notice @kyle this and change the product from the website............
iPhone 5s/SE Front Camera and Sensor Cable ????
这个答案有帮助吗?
得分 8
6条评论:
Yes, I have run into this exact problem MANY TIMES. 5S proximity sensor flex cable will not work properly on an iphone SE. Everything works except Siri Mic and Dictation Mic because the Mic is different. Also, 99% of cellphone parts suppliers do not know this and list part as the same for the 5s and the SE.......But they are different....Where can i get an OEM iPhone SE front proximity sensor flex cable from??? anybody know ??? 5S will not work on SE!!!!!!
由完成的 分享
But why does ifixit website list the parts as iphone 5S/SE front camera flex ? If they clearly know this part is not the same?????? WHY????
ALSO, WHERE CAN I GET AN IPHONE SE ORIGINAL FRONT PROXIMITY SENSOR FLEX CABLE ASSEMBLY ? 5S WILL NOT WORK!!!!
由完成的 分享
Sup Bro I found out where to buy the original ones I have use it and it works buy from Rewa technology.
由完成的 分享
I need the real SE part too
由完成的 分享
@xterminal Which part did you order on the Rewa technology site? I don't see an iPhone SE category listing
由完成的 分享
显示更多的1条评论
添加一条评论
Having the same issue, anyone got it working ?
这个答案有帮助吗?
得分 0
添加一条评论
where can i find an original iphone se front proximity sensor flex cable?
not a 5s proximity sensor flex cable assembly because mic wont work.
这个答案有帮助吗?
得分 0
2条评论:
were you able to find one? i need it too
由完成的 分享
Here Bro I have tested https://amzn.to/2G7SNKT
由完成的 分享
添加一条评论
I’m having same issue. Pls let me know where to find iPhone SE flex cable
这个答案有帮助吗?
得分 0
3条评论:
Amazon has them for SE now. About $15each.
由完成的 分享
I have tested this ones https://amzn.to/2G7SNKT
由完成的 分享
Is it tested on A1723 Iphone SE model ?
由完成的 分享
添加一条评论
Thanks, same issue and behold, I’m using a SE with a 5S front.
这个答案有帮助吗?
得分 0
添加一条评论
I have ordered a complete display replacement for the iphone se.
Now I have run into the same problem, that the front mic is not working.
I replaced the original sensor cable, and now it is working.
I am wondering, if this was a similar issue ?
这个答案有帮助吗?
得分 0
添加一条评论
You are using the wrong part. The iphone SE and 5S use a different front camera flex cable. They make one specifically for the SE that will resolve your issue. Some of the these suppliers do not even know this and list the part as compatible with both 5S and SE but that is 100% FALSE.
Hope this helps !!!!
这个答案有帮助吗?
得分 0
添加一条评论
iPhone SE Vibrator - and INSTRUCTIONAL VIDEO
https://www.fixez.com/store/iphone/iphon...
iPhone SE Front-Facing Camera and Sensor Cable - and INSTRUCTIONAL VIDEO
https://www.fixez.com/iphone-se-front-fa...
这个答案有帮助吗?
得分 -1
1条评论:
由完成的 分享
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 6,040
