跳转到主内容
加入维修社区 - 创建账户
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
half the screen has dark lines
Half of my screen has dark lines going through the left side of the screen and it will not respond to my touch. The battery is also overheating each time I put it to charge. What do I need to do to fix both of these issues?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
Is the screen cracked? Waterdamage? Repaired before?
完成的
Hey Cristal, I would defiantly like a little more details, how did it get like this? Did it drop or has the device been exposed to water?
完成的
添加一条评论
4个答案
The screen is not cracked and has never been repaired before. About one month ago water did get to it but it did nothing to my phone. My now ex boyfriend had slammed my phone on the ground 2 to 3 times.
这个答案有帮助吗?
得分 0
添加一条评论
Whoever had slammed your phone has caused the problem. Get a new screen.
Update (02/02/2017)
Is it cracked? How long have you been using it? If you have been using it for a long time, try getting a new battery. If it's cracked then you should get a new screen. If it's not cracked then open it and if there isnt a wire connecting to the screen, look at a teardown to see what goes where.
这个答案有帮助吗?
得分 0
添加一条评论
I have a similar issue and saw that with a dif. model several people had the same problem as well. The prevailing sentiment is that it is a defective battery and can be fixed by replacing said battery.
这个答案有帮助吗?
得分 0
添加一条评论
I replaced the battery, but the screen still has black lines and won’t repond to touch.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cristal rosales 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 2,434
