跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface Pro 2 是一个2013年发布的二合一平板笔记本解决方案。 Surface Pro 2 是 Surface Pro 的继任者,预装 Windows 8.1 并能升级到 Windows 10
LCD ribbon cable dmg
Hi,
Today got new LCD display + touch after I connect everything nothing dosent show on screen but surface sound as working. Also when setup old broken lcd nothing happent. So I think lcd ribbon cable is dmg , here is image of cable https://postimg.org/image/xemi57umf/ i, down right corner look as dmg missing small part of connector. How can I fix? Because new cable cost 50$ , so if can will like to save that money
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Hi,
I solved problem by replacing ribbon cable. You can find on alibaba for arround 5$.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem. I brought and connected up a brand new LCD screen for my Microsoft Surface Pro 2 but although all the sounds and vibrations are working perfectly on the device I can't seen to get the display to show any visuals. Has any body had and solved this issue and if it is a faulty display ribbon, does anyone know where I can buy a new one from for a reasonable price.
Thank you.
Kay
这个答案有帮助吗?
得分 0
添加一条评论
Cheers Flegy.
I've ordered a new ribbon from Alibaba but couldn't find the same sort of bargain as you. I paid $18.
这个答案有帮助吗?
得分 0
1条评论:
Ye when I was order before few years cable was cost 5$ now price is from 10-20$
http://s.aliexpress.com/6zaMZzuu
由完成的
添加一条评论
Same issue. You may find that the screen works but it's the back lights that aren't functioning. You can test this by angling a flashlight to the screen while the unit is on. You should be able to see the graphics but very dark. Another way is to connect the mini display port to an external monitor. This worked for me.
Back to the issue. I replaced two screens and one costly cable but none of that helped. I have the option of connecting to a docking station. My Surface Pro 2 can no longer be used as a tablet.
这个答案有帮助吗?
得分 0
1条评论:
So sad to hear you didn’t solved screen problem. I replaced on my surface LCD + ribon and it work fine.
由完成的
添加一条评论
添加你的答案
flegy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 35
总计 2,233
