跳转到主内容
加入维修社区 - 创建账户
HTC One X 是 HTC 首款搭载四核处理器的手机,于 2012 年 4 月发布。
Why my phone screen blinks?
My htc one x plus phone automatically get off even if the battery is full. i had repaired the IC of the phone , it worked for 2-3 days then again it is off. can you please tell me whats the issue? whenever i press the power button the screen blinks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Can you tell me the exact conditions of you're problem pleas? Does the phone shuts itself down if it is just placed on a table or not? And does the screen just blink 1 time or several times? And does the phone the same thing when it is plugged in?
完成的
Hey . Whenever i press the power button to start the phone HTC ONE X Screen Came and it goes. This screen blinks everytime. It shuts down by itself. Whenever i press it blinks. Even when its plugged in it does the same thing.
完成的
添加一条评论
1个答案
Well, that sounds like you're screen has a loose connector, i sugest you open up the phone, search through the guides to find the guide that is conform woth you're phones model, and that you fix this loose connection, the problem can acure when the phone has been dropped on the floor or that you dropped the phone to hard on a hard surface. Open up the phone, locate the screen connector on re-connect the connection properly, i hope this may help you. Greetings
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Akshita 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 858
