Why has the camera locked up?
Camera is frozen. Screen is on (special effects/image mode) & lens extended. Camera will not turn off or respond to menu, playback or directional keys. What do I do to un-freeze /unlock it?
Didn't see any answers, so I simply opened the battery/SD compartment and removed SD chip then battery. Put them right back in and everything is working again as it was before it locked up.
这个答案有帮助吗?
I ended up trying this and it actually worked, thank you!
yes, it worked! Thank you for sharing your idea.
Thank you, that worked!
Thanks a mill...it really worked
This worked untill I try to zoom in and then it freezes again
The best solution is using a SD Memory Card with great data transfer rate, like Sandisk Extreme Pro 95MB/s.
After change SD Memory, the camera has not been frozen or made this issue! Hope it help.
这个答案有帮助吗?
My memory card is a SanDisk Extreme 64 GB with "45 MB/s" on the label. Is this really too slow for photographing my dogs in the Scene Sport mode of my Nikon CoolPIX P950? It may be time for a faster card.
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 11,423
