Thin red line on TV screen
Hi,
I have samsung UA37D5000 tv. There is thin vertical red line appearing in TV. When I called up the local samsung service guys to check, they said they have to replace the panel and costs almost 23K. I don't believe in their words. Will you be able to tell if it's the real panel issue or some board issue.
If I have to open the TV, it would be helpful to have a teardown guide for my TV.
Attached the picture of the red line on the screen.
Thanks
Rajesh
I have same issue
由 karenggivens 完成的
karenggivens same TV? Same issues? If so then it is the same answer. TAB error.
由 oldturkey03 完成的
I have 40" Samsung Curved LED TV. I have the same problem. Vertical line is approx one feet from left side and stationary. Please suggest.
由 Siyaram Verma 完成的
I have the same problem. I check the tabs, applying pressure where the red vertical line originated but it did not solve the red line problem. What else could it be?
由 brennan.moore99 完成的
so ii have to dismount the back from the tv ???
由 AMD RX460 Gaming and Xbox 完成的
显示更多的9条评论
