跳转到主内容
机器可读指令,可以指导计算机处理器从互联网上下载和渲染“猫”的图像。
SQL server after RAID problems
We had a SQL server die due to some RAID problems. We sent the machine out to a data recovery company and they are able to recover the .MDF and .LDF files from the drives. Will I be able to use those files to restore the databases to a new machine?
What do I need to watch out for? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
You've been very kind in your efforts to help. Thanks for that. Solved!
完成的
添加一条评论
1个答案
已选择的解决方案
Have u tried out the old way of creating empty database with same name.
Stop sql server
Paste database at the same location ...
And restart the server ....
Does it helping u out .....
If that doesn't help, then the only thing I can advise is to try to restore database using SQL Server Recovery Toolbox. All the details about this program can be found at the link. http://www.oemailrecovery.com/sql_repair...
这个答案有帮助吗?
得分 1
1条评论:
May be this article will give you more information.
http://www.techrepublic.com/forums/quest...
完成的
添加一条评论
添加你的答案
DanielNetrval 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 699
