跳转到主内容
加入维修社区 - 创建账户
Asus Transformer Pad TF103C 是一款于 2014 年 6 月发布的 10.1 英寸安卓混合平板电脑。它专为娱乐用途设计,具备 WiFi 功能。
Touch screen not working
Hi,
I'm having issues with my Asus tablet running Android Lollipop. For the past few months, the touchscreen would stop working momentarily, then everything would come back to normal after a few restarts. It was more likely to happen when the tablet was charging though. At some point I found a weird hack that was plugging the tablet for a second every time it happened.
Now for the past few days, this would work and the tablet is now useless without its keyboard. I've read on some forums that the Battery Saver app could be the cause. Indeed I noticed a bug with it because every time the tablet was charging I would get a notification saying that an app was drawing too much power, but the Battery Saver app would crash every time I tried to open the notification.
Last night, I disabled the power saving mode and rebooted the tablet (as suggested in the forums) but it didn't do the trick.
This morning, I tried to reset the tablet both via the settings menu and recovery mode, but then touch screen is not working. I also tried to "swipe cache partition" but none of this would work.
Is there anything else I could try? I'm not sure if it's a hardware or a software issue, but as far as I remember the tablet has not received any impact in particular and there's no scratch at all on the screen.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
8条评论
I have exactly the same problem, did you find a solution? thanks in advance.
由完成的 分享
No, and this will make me think twice before buying other Asus products.
由完成的 分享
I used to have the same issue and the I used to dindn't mean that the issue was fixed what happen to me is the tablet is now completely dead, very disappointed about asus a brand that I used to love but the quality is so bad now, in other hand lenovo products are super cheap now and durable too, by the way I'm an IT guy and I handle this kind of products every day
由完成的 分享
Hello,I have same problen and I find the system repair program from Google Play(that brown logo).Then I was ran the program,I put the device to factory setting.Then it start the work.It works untill now I typing tekst.Good day.
由完成的 分享
Hello agen.Notice that programs that you installa on Asus transformer Pad,can make issues to it.My ATP:s screen touch stops working and I delete all new programs on it.Good luck.
由完成的 分享
显示更多的3条评论
添加一条评论
9个答案
最有帮助的答案
Actually, my cable solution only worked for a short period, then it stopped again. So I tried the pigtails to the screen, as per Rod H's post. But again, it still only worked for a week or so.
Then I had a think about the connections to the screen: they come into the same small sub-board as the USB connection, and both the USB power/signals and the touch screen signals go through another pig tail connector to the main board.
I thought that it is possible that the movement of the plugging and unplugging of the USB (as per Andre's original post) might disturb the connectors.
So I reseated the pigtail connector going to the main board as well. That was over a month ago, and the problem has not come back.
I hope this works for you as well.
这个答案有帮助吗?
得分 2
3条评论:
here is the video that helps: https://www.youtube.com/watch?v=nCGkshgs...
由完成的 分享
Thanks for the video, it seems to work now. I think you should create your own answer instead of a comment
由完成的 分享
It only worked for a few minutes for me.
由完成的 分享
添加一条评论
See my message in one of the other threads about the same issue, same model
这个答案有帮助吗?
得分 0
2条评论:
do you have a link to that?
由完成的 分享
Why won't my touch screen work
Sorry for late reply, Ifixit didn't inform me about your question. You can always click on a user's icon to see their contributions
由完成的 分享
添加一条评论
I just found in another post that the digitizer cable can come loose or detached from heat
这个答案有帮助吗?
得分 0
3条评论:
No, it"s definitely a software issue. I'm able to use it after I play with the charger (plug/unplug/sleep/wake)
由完成的 分享
Only if you can replicate both the problem and the way to fix it, you can be sure that it's (in your case) either a hardware or a software problem. There are people who have a dead touchscreen each time after wake up from sleep and revive it using a cold reboot.
In my case such a solution or for example draining and recharging the battery sometimes seem to work... but more likely it's simply the mechanical handling (laying down, closing screen on keyboard, connecting, disconnecting that might or might not accidentally make or break the delicate loose connection . Because in my case it does work 100% of the time to open the back and press the flatcable firm into its slot. It keeps coming loose from time to time so perhaps I should fixate it , hot glue or so?
由完成的 分享
I've seen other people mentioning this issue on other forums. I'll try flashing the tablet again and see how it goes. Again, I'm 99.999% it's a software issue. Even the Windows version of the tablet has this, but it's easier to fix (with a few tweaks in the Windows settings that unfortunately Android doesn't have).
由完成的 分享
添加一条评论
I also found this issue with a TF103C tablet. I opened the case and re-seated the screen pig-tails and the screen became fully responsive. Then some time later the screen was again unresponsive. I'd read that a static buildup on the screen can cause the screen to become unresponsive so I opened the back but this time just touched the screen pigtail connector rather than re-seating the connector. Again the screen regained its touch control. I think there's something to the static build-up theory and will use that fix in the future.
这个答案有帮助吗?
得分 0
4条评论:
Is there a tutorial or something on how to open it? I'm not really comfortable with it, how hard is it for someone who has never opened a tablet or a phone?
由完成的 分享
由完成的 分享
Interesting​. Can you show the cable to play with? Is it easy to reach? Thanks
由完成的 分享
Are you think programs that you install it?My opinion is that if you download lot of programs that is not optimise your pad,then it can bad.
由完成的 分享
添加一条评论
where the finger points
这个答案有帮助吗?
得分 0
1条评论:
So should I just touch it?
由完成的 分享
添加一条评论
Well, I swapped in a digitizer/screen (unplugged the old one and plugged in a new one that I left on the desk) and it made no difference on mine
这个答案有帮助吗?
得分 0
添加一条评论
Hello.
I fixed this by:
a) Powering off
b) Opening the back cover
c) Disconnecting the battery for about 10 secconds
d) Re-connecting the battery
e) Restarting.
Thanks.
BC
这个答案有帮助吗?
得分 0
1条评论:
Thanks so much. I followed your advice to the letter, after which I was able to use the touch-screen to full effect. Thanks again :)
由完成的 分享
添加一条评论
Hi. I had this problem too. I bought this tablet 2days ago as used. And it started no responsing after first charge.
Result from reading different forums - disconnect flex cable from docking connector inside tablet.
Also re-connect, just for sure, touch/screen double flex cable (on right side down under silver tape).
I am using it as a tablet without docking to keyboard. Therfore such solution.
这个答案有帮助吗?
得分 0
添加一条评论
Connect keyboard via keyboard slot or via USB and turn off Power saver in Settings and touch will work again
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andre 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 39
总计 37,839
