跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Can I upgrade from 2Gb to 3Gb RAM
I have a MacBook 2.4GHz Core 2 Duo model 1181 (Penryn). I understand that this model can only address a maximum of 3Gb of RAM. If I want to upgrade my RAM, can I replace just one of the two 1Gb chips to a 2Gb chip in order to obtain the maximum 3Gb addressable? Or do I need to upgrade both of the 1Gb chips to 2Gb chips? In other words, is it necessary to have symmetry between the 2 RAM chips, or will a combination of one 1Gb chip and one 2Gb chip work correctly? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
*Apple officially supports a maximum of 4 GB of RAM but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
http://www.everymac.com/systems/apple/ma...
这个答案有帮助吗?
得分 4
2条评论:
I'd go with the 6GB
完成的
Agreed +
完成的
添加一条评论
You can use these chips.
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 200 pin / DDR-2 / 667 MHz图片
产品
PC2-5300 2 GB RAM Chip
$11.99
产品
PC2-5300 4 GB RAM Chip
$49.99
这个答案有帮助吗?
得分 2
添加一条评论
Watch out for anything other than 667 MHz! I just bought 2 2GB 800MHz chips that don't work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 4,322
