跳转到主内容
加入维修社区 - 创建账户
适用于配备 GSM 3G 蜂窝网络(AT&T)的第二代 Apple iPad 的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储容量可选。采用双核处理器。于 2011 年 3 月发布。通过型号 A1396 进行识别。维修时需要使用加热工具并小心撬开。
Backlight does not work ...
My iPad 2 has fallen down.
Since then there is no backlight (the screen seems to work fine because when I use a torch I can see everything on the screen) and also the digitizer cracked.
I have removed the cracked digitizer carefully and checked inside the iPad for further damage which could explain the backlight failure. But I couldn't find any other damage. Everything looks OK.
How can I find what causes the backlight malfunction. Is it the screen or is it something on the board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hello again
I cleaned the connectors from the logic board and the LCD screen, but still no backlight. Then I tried to hold the power and home button for 15 seconds and nothing happened. The iPad just turned on. What am I doing wrong with the power and home button combination?
I would also like to ask something else. Is there a schematic or something like that for the backlight circuit so that I could find the right components and test them by using a multimeter? eg voltage, resistance, continuity, etc.
由完成的 分享
If you search up Louis rossmans YouTube channel you may be able to find it there.
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
I would say try cleaning the LCD cable connectors from the logic board and the LCD screen itself and at the same time try reseating them and hold the power and home button at the same time for 15 seconds and try turning it on again.
It could either be a faulty screen or the backlight component(s) on the logic board have become broken.
No signs of any physical damage on the LCD screen correct? Well since you can still see display but without backlight I'm leaning more towards logic board component damage like I said before.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Socrates Gertsos 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 20
总计 409
