跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
How to remove adhesive glue?
Hi everyone,
I'm replacing the glass of my iPhone 3GS because it was cracked. I have separated the glass from the bracket with a heat gun. But how do I remove the glue residue that is left behind?
Thanks,
naf
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I use isopropyalcohol as it's not likely to cause liquid damage to any parts and either a small flat head screw driver or plastic spudger tool to scrape it off. it's fiddly and annoying but you can also just use your fingers to roll it and pull it off.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
With a q-tip, try using a bit of Goo Gone or Goo Off. A small amount goes along way. After you've removed the residue, use another q-tip with ALCOHOL to remove any oils left behind by the Goo Gone/Goo Off. That's what I do for all my electronics.
这个答案有帮助吗?
得分 2
2条评论:
+ for the goo gone
完成的
Goof off and goo gone are NOT suitable for plastics. It will damage it
完成的
添加一条评论
添加你的答案
naf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 5,850
