Are the cases from each A1181 model identical?
I may be purchasing an as-is black A1181 MacBook, and the possibility for a logic board replacement being needed seems likely. If I do end up buying a logic board, will any A1181 board work? If that's the case, I'll definitely buy the 2.13GHz Penryn board and put it in. Or do I need to buy the same exact board that was originally in the machine?
这是一个好问题吗?
