跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
Dropped by mistake phone in toilett.
Hi...
As stated, my S6 Edge has taken a bath in the toilett.
The phone was not starting for 1 day.
Now the phone is starting only then battery charger is connected.
The phone say that the battery is 100 % charged.
Then I disconnect the charger then running, it just dies.
Sometimes when I try to boot I have to do Volume Down + Hometab + On buttom and then choose cansel then screen boots up. Then the phone boot up.
I have done a faktory reset.
I wonder, which parts is most likely to be changed?
Regards
A clumsy person :(
Update (07/10/2016)
Hi again...
I have now cleaned the phone inside and changed battery and charger port.
Problem still exist.
Any other solution I might try?
/NBonline
Update (07/16/2016)
Hi again...
Tested with disconnecting the battery from motherboard for 6 hours .
When i connected it again I could start the phone without charger and it show probably the right battery status.
After abaout 6 hour the phone went dead again. It worked perfeclty until then.
Time to test it again and see if it get any better.
/NBonline
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Thanks for quick responce!
I will take it appart and clean as you advised.
Do you think anything else appart from battery should be replaced?
/NBonline
完成的
Not until you know what you have after you clean it and replace the battery. That is truly only the beginning of the trouble shooting. It give you a clean starting point.
完成的
Ok, thanks again for fast answer. I will do a cleaning and replace battery, then will se what happens.
完成的
Hi again...
/NBonline
完成的
添加一条评论
2个答案
最有帮助的答案
@nbonline I totally agree with @galmoham At this point you have to treat it like any other water damaged phone. The very first thing you want to do is to not try to restart the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides Remove all EMI shields from your phone, then clean it with +90% isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best way to clean it would of course be through an ultrasonic cleaner, so you may consider a professional service . Once all this is done, reassemble your phone and reevaluate.
这个答案有帮助吗?
得分 2
添加一条评论
i think you should disassemble and clean inside with rubbing alcohol ... if you have done this earlier when this happen you wouldn't have had any problem because the phone is waterproof
这个答案有帮助吗?
得分 1
2条评论:
I dropped my phone in curry and I turned my phone on it was working for 5mins and then stopped working I have left it upside Down to see if it drips out and it still won't work how can I fix this problem?
完成的
drop the phone in a bag of rice (cover it completely with the rice) for about a day and see
完成的
添加一条评论
添加你的答案
Niclas Brorsson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 207
