跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
My internal display not working.screen, inverter, cables ok.
i have a black macbook 2.2 that suddenly went to a white screen while in use.. all i did was move the screen/tilt and it happened. still showed desktop on external monitor for a few minutes then external only showed extended desktop. have replaced the lvds cable, tried a working screen/inverter/lvds from another working mac: no avail. would the video card or another chip need to be reworked? swaped ram..nothing.. please help. thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
If the external monitor is working (I'm not sure what you mean by "extended desktop"), then there are only four things that can be fixed.
The Display Data Cable: MacBook Display Data Cable
The inverter: MacBook Display Inverter
Check to see if you can see the desktop by shining a flashlight on the screen at an angle.
The LCD: MacBook 13.3" Santa Rosa/Penryn Display Assembly
The Inverter Cable: Apple part # 922-8281: http://www.welovemacs.com/9228281.html
MacBook Display Inverter图片
产品
$14.99
MacBook 13.3" Santa Rosa/Penryn Display Assembly图片
产品
$299.99
MacBook Display Data Cable图片
产品
$19.99
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
Before replacing the LCD, you might try to reset your SMC. It may work for you if you have already replaced the inverter and inverter cable.
http://support.apple.com/kb/HT3964
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ALFIXN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,908
