跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
Broken LCD temp sensor connector on logic board
I own mid-2010 27” iMac
While attempting to do the HDD swap, I broke the LCD temp port that's attached to the logic board, and now the cable doesn't connect properly. As a result, the fan is going maximum. The sensor cable is fine, it's that port on the logic board that's broken.
What's the part number for this part and what would be the best way to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Please post picture of damaged area.
完成的
I will later tonight, but the connector on the logic board is broken, I accidentally pulled it while I was trying to remove the lcd panel. I think the cable is fine, but the connector is broken and the pin won't sit properly.
完成的
添加一条评论
2个答案
You might try just soldering the wires directly back onto the board. That should make things work again simply.
这个答案有帮助吗?
得分 0
1条评论:
Yes, I'm gonna try that but I need to buy the replacement part because mine is broken.
完成的
添加一条评论
@jiwoongyou I am certain you have this fixed by now. Answering this just for completion sake. That particular connector is a Molex 53261-8602.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ji Woong You 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 3,735
