跳转到主内容
The Tegra Note 7 is made by Nvidia and branded by graphics firm EVGA. This device is known as the EVGA Tegra Note 7 in the United States, Cherry Mobile Tegra Note 7 in the Philippines, Advent Vega Tegra Note 7 in the United Kingdom, Gigabyte Tegra Note 7 in Australia and New Zealand, Gradiente Tegra Note 7 in Brazil, Gazer Tegra Note 7 in Ukraine and Russia, and XOLO PLAY Tegra Note 7 in India.
6 个问题 查看全部
TN7 stock battery replacement
Hello experts, the battery performance of my TN7 has gone really worse that I have to charge it at least thrice a day.I wish to switch the stock battery with a bigger one but don't have enough technical information about this. So anyone aware of this,be generous enough to share the info.By the way,thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@noufi "has gone really worse" is most likely a battery issue. In the case of your tablet replace the battery with a new one. There are no larger replacement out there. Check your setting and background apps and ensure that you run the latest OS version on it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Noufal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 908
