跳转到主内容
宏碁所制造的台式机的维修和支持指南。
70 个问题 查看全部
WiFi completely gone, no networks
I was disconnecting/reconnecting wifi for a reason I can't remember. Next time it shows no networks at all and I can not connect I restart assuming it would resolve the issue but it didn't, i tried restoring it to a previous point but that also did nothing
wifi card is fine in device manager
any ideas that don't involve replacing the antenna lol? this is all in one machine and a night mare to repair
thanks all
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Does it "see" any wifi networks and can you see the wifi status symbol in the corner doing anything? What model is your PC, what OS are you running, and is the wifi card aftermarket?
完成的
添加一条评论
3个答案
最有帮助的答案
Hello David F im my opinion it could the the drivers of the wifi are corrupted this is not a 100% sure that could be the problem but since you say that is a all in one Desktop I really dont trust AIO PC.
You could download this free Legal program that will install 100% updated new drivers (driver park solution)
https://drp.su/index.htm
This could fix your problem with the wifi driver
HOPE THIS SOLVE YOUR PROBLEM :D
这个答案有帮助吗?
得分 1
1条评论:
i will try thanks
完成的
添加一条评论
Open Network and Sharing center
On the Left click "Change Adapter Settings"
Right click on one of the devices/options on the right hand side and make sure that they are enabled!!
这个答案有帮助吗?
得分 0
添加一条评论
Just put a bit of vinegar on it pet !
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David F 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 15
总计 598
