Phone will not charge
My phone will not charge. All it does when I plug charger in. Screen stays at 0% (screen shows this) but that's it.. will not charge
Try replacing the battery like the other comment said. At my phone shop that would be one of the first things we would try. Also try a different charger that might be the issue, the charger you are currently using may not be giving out enough power to charge the battery.
这个答案有帮助吗?
Did that, replaced the grey battery with an aftermarket one off Ebay. It's been 8 months. Now the phone won't charge again. Did the USB cleaning. Changed chargers. Still it gets hot when charging. Won't charge phone says “slow charge” not sure what to do next
这个答案有帮助吗?
I done everything change battery change charger.its says 0 charging charge before using I put on charging 5 hour same problem showing me again
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 3,975
