跳转到主内容
Yamaha YPG-225 76-Key piano keyboard, released in 2006
11 个问题 查看全部
plays for short time and goes off
My yamaha keyboard plays for shot time and stops to produce sound even when power is on. To make it sound a gain I had to hit one of the speakers wire on one of the transistor. That left speaker as well doesnot work. This has been disturbing for the last 2 weeks. What could be the problem and how do I fix it?
Update (06/15/2016)
Here is the picture of the transistor that I rubb on. Another thing is that, the switch as well does not work, when I plug in the dapter the power goes direct.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@oluka "I had to hit one of the speakers wire on one of the transistor." explain this a bit better. what transistor?
完成的
添加一条评论
1个答案
最有帮助的答案
@oluka not sure which "transistor" you had to hit. Add an image of where and what you hit with your question. For that use this guide. I'd suggest that you get your multimeter out and check the output starting at the power amp IC 551 and measure from there to the L speaker to see if you have the correct output.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
oluka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 185
