跳转到主内容
Support for the CQ57 series of Compaq notebook computers.
38 个问题 查看全部
screen is all broken
do you sell screens for this type and tools for it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
dannymesser18 ifixit does not stock displays for that computer. Check online for HP part number 645095-001 if your computer is equipped with webcam and 645094-001 if not. Download the maintenance guide from the bottom of this page. No special tools needed just a set of Philips screwdrivers
这个答案有帮助吗?
得分 2
1条评论:
Your LCD display 645094-001 uses a LED backlight, not CCFL.
完成的
添加一条评论
Try here
It's an easy fix and should require no more than a Philips head screwdriver. Take the old LCD out first to ensure you are buying a screen with the right connector (LCD or CCFL) as they sometimes vary.
Once you get the old LCD out you will see what an easy job this is. Just take your time and be careful! :)
这个答案有帮助吗?
得分 1
2条评论:
how would i tell which one it is
完成的
A CCFL has an inverter to power the backlight. LCD hasn't. So the easy way to tell is if there is just the one ribbon connector or whether there is an additional 2 pin plug that connects to the inverter
完成的
添加一条评论
Hesitate to state the obvious but...maybe it is time to throw it out!
这个答案有帮助吗?
得分 -1
1条评论:
Sandy Perkins why? Spending $40USD and repairing the LCD to have a working laptop and keeping devices going, is a very sensible thing to do. Read this Fix the planet before giving that kind of advice.
完成的
添加一条评论
添加你的答案
dannymesser18 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 173
