跳转到主内容
加入维修社区 - 创建账户
PlayStation 3(通常称为 PS3)是索尼电脑娱乐公司生产的第三款家用电脑娱乐系统,也是 PlayStation 2 的继任者。它于 2006 年 11 月 11 日发布。
The appropriate system storage
My PlayStation won't go to the home screen won't do anything but say cannot start the appropriate system storage was not found. What do I do
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
9条评论
I had this problem as well. My ps3 has gotten knocked off the shelf and as a result I got the same fault. As it turned out the hard drive was not fully seated and it wasn’t connected. I pushed it in about 1/8” and system is normal.
由完成的
Thhaannnkk u!!! I was sad and thinking like am I gonna have to buy a new game and I'm only 13 and I have currently 4 dollars in my wallet. MAY GOD BLESS YOU. And I'm talking about Dennis Lee
由完成的
You’re very welcome
由完成的
I just got in my replacement hardrive but it didn't make that error go away. Is my PS3 just dead?
由完成的
contact. I have the same problem. Did you fix the problem you had and if you did what did you do?
由完成的
显示更多的4条评论
添加一条评论
2个答案
已选择的解决方案
Most likely the hard drive has gone bad.
You could try reseating the system storage drive which is located inside a compartment on the side of the PS3. It will require a phillips head plus screwdriver to take out the hard drive secured to the hard drive cage as a screw stops it from being taken out or moved.
Here's a guide on how to replace the hard drive if it is faulty:
PlayStation 3硬盘更换
You can buy the hard drive from here:
500 GB 5400 RPM 2.5" Hard Drive
Or literally any 2.5" hard drive or SSD will work as well. Just make sure it's at least 120GB or more. You will most likely need to download system software when installing a new hard drive.
Replacement or upgrade hard drive compatible with all MacBooks, MacBook Pros, Intel Mac minis, and Sony PS3 and PS3 Slim game consoles. SATA interface for Intel Macs / 2.5" wide x 7mm tall / 500 GB Unformatted / 5400 RPM图片
产品
$103.99
这个答案有帮助吗?
得分 6
3条评论:
Man thank you....
由完成的
How to fikxi cannot start. The appropriate system storage was not faund
由完成的
@baraka46235 what speak english
由完成的
添加一条评论
For future people, try this. Once the console is off and unplugged, On the left side of the ps3 (I have the cechg01 so yours may vary slightly) there's a little cover. Pop it off by putting a flathead screwdriver (or anything flat and small) into the little notch and pop it off. There will be a little blue screw that you need to take out.
Unscrew it once you do that there will be a little metal handle on the side of the hdd tray, lift that up and pull the hdd the the right (again may vary slightly based on ps3 model). Once you unplug the HDD from the console, try blowing onto the contacts of the HDD and then blowing into the bay to the left where the plug is on the mb. Then put it back in. You can screw it down again but its not necessary.
Try turning on the console again from there. If you get the same do the following:
Turn off the console, wait for the red light to turn on, then press and hold the power button until it turns on and off again. when you see the red light again, press and hold the power button until you hear 2 quick beeps, should go 1 beep wait a few seconds 2 beeps. Once you hear 2 beeps let go of the power button. You should now be in safe mode. From there there should be an option that says system update. Follow the following guide to get the update onto a usb: https://www.playstation.com/en-us/suppor.... Once you have the update on the usb, plug the USB into your console. Click on the system update and follow the instructions on screen.
If you get an error again installing the system software from safe mode, try getting a new hard drive. If you have a spare one, great! Just repeat the second trick, installing system software from safe mode, once you have the new hard drive installed. The new hard drive as it is new and doesn't have anything on it, will of course throw and error if you try to regularly boot up.
If a new hard drive doesn't work after that then from there I have no clue what could be wrong but its possible that the hard drive connector on the motherboard is damaged.
这个答案有帮助吗?
得分 1
1条评论:
I have a 500 gb hard drive and I’m only using 1582 mb and yet tells me not enough room to install games.
由完成的
添加一条评论
添加你的答案
Nichole 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 44
过去 30 天: 221
总计 84,859
