跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
iPhone 6s FPC Replacement
Hello,
I need to know if it possible to replace the FPC connector for the LCD and digitiser for the iPhone 6S as i believe i have damaged mine while replacing the screen - the LCD comes on but the touch response on the screen is not working. Any company in the UK would be appreciated however I am willing to post overseas
Thanks
Update (06/07/2016)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
why not order an new one to fix it yourself ... it is very easy to do and there is a guide HERE but if you mean the onboard connector you can post a picture of your board for us to see how much damage you've caused and a why to help-out..
这个答案有帮助吗?
得分 2
2条评论:
Hello there,
It's not the display i am worried about, it's the actual connector itself, I'm afraid i may have damaged one of the pins and this is what is causing the touch not to work.
完成的
this wont be anything easy to repair... and expect with good soldering experience will be required to repair this as this will require profession soldering station(If replacement of the connector is needed)
完成的
添加一条评论
if you want to get it fixed in england, google leon stacey... he is a really good repair expert
这个答案有帮助吗?
得分 0
添加一条评论
Hi my fpc is not working but it is fashing with the apple logo
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Faheem Rahman 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 20
总计 2,474
