跳转到主内容
This model was released years ago and continues to be produced. The disassembling is straightforward as long as you follow the instructions.
8 个问题 查看全部
How do I disassemble my Wahl Stainless Steel Lithium Ion + Groomer?
I researched and bought a Wahl Stainless Steel Lithium Ion + Groomer to help me stay within regulations as I was deploying to the Middle East.
During my research I found a number of complaints about the on/off switch failing and the ability of the groomer to accept a charge.
Initially the unit I bought worked well and had no problem with either the switch or charging. However, after owning it for about a year with light use, both of these problems emerged and now I can only turn it off by inserting the plug in the recharging jack.
In order to repair/troubleshoot the problems I need to know how to disassemble the razor/groomer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
2条评论
Anyone able to find a good source for replacement batteries with soldering tabs?
完成的
Hi! This post couldn't be composed any better!
Perusing this post helps me to remember my past flat mate!
He generally continued discussing this.
[url=https://www.hairnode.com/wahl-5-star-mag...]wahl designer vs magic clip[/url]
完成的
添加一条评论
7个答案
已选择的解决方案
Hopefully this IFIXIT guide will help you: Disassembling of Wahl Lithium Ion Trimmer
这个答案有帮助吗?
得分 5
2条评论:
This link won't work because it's for the regular lithium ion, not the stainless steel. I have this problem too because I can't find a safe way to remove the silver led display off to get to the screws inside. Faulty production engineering?
完成的
For the stainless trimmer you'll need to pop the rubber power button off to access the screw under it. Use a thin knife point to get under the rubber and pry away from the shaver. After that, you can get to the two case screws under the bezel.
This is all a moot point due the the fact that I have ohmed all the hard wires on mine, only to find that there is something within the boards that is not allowing it to accept the charge or that will initially start charging, but then stop shortly after. It may be that the battery is sending out a false full charge signal...TBD
完成的
添加一条评论
最有帮助的答案
Here’s a picture of the 9818L model and the placement of the hidden screw.
Here’s some other pics of the 9818L (Lithium Ion+® Stainless Steel) that might be helpful:
这个答案有帮助吗?
得分 10
5条评论:
mine is not charging light goes on but turns off
完成的
Absolute legend, thank you. Saved me trying to pry that gold thing off the main frame :D
完成的
Awesome teardown pics Mark, mine had both a loose switch screw and a dicky charging socket, I'm just waiting on the power socket and hopefully it'll be good for another 5 years!
Question though, mine had a tonne of hair inside the casing and underneath the switch cover, was yours the same?
Due to this I chucked everything non electrical in my ultrasonic cleaner to clean it up which worked well EXCEPT it seems the outer stainless steel housing has a lacquer coating on it which has now partially come off :(
完成的
The power button is rubber glued to a plastic backing plate which has four tiny clips. The entire button comes out as one unit. I used a scalpel to reach behind the backing plate to pop it out. Don't snap the scalpel blade. The button shouldn't be bent over as in the first photo.
完成的
When removing the button/rubber be careful. Mine is probably close to 5 years old and when I did a battery swap a few months ago the button and rubber pretty much disintegrated and I was very careful. I ended up cutting a piece of a regular yellow rx bottle to the exact size and cut up a rubber jar opener for the rubber part but it probably would have been fine without it. Start to finish took maybe an hour and a half, with a good 30min looking for materials to replace the button and rubber.
完成的
添加一条评论
Solved my problem! ! I used the shaver until it died, plugged it in and left. When I came back hours later, my trimmer wouldn't turn on, and if I plugged it in the blue light would flash and do not more. While attempting to disassemble it, I discovered the screw under the power button was loose and partially backed out. If I pressed the power switch without the button in place, the razor tured on. By tightening the slightly, everything works normally
这个答案有帮助吗?
得分 3
3条评论:
Thanks for sharing that! I have exactly the same problem with mine. Can you please describe how did you manage to get behind the button as it looks glued in. Thanks again
完成的
The rubber power button is glued to a plastic backing piece. slide a small flat-head screwdriver down beside the rubber and the plastic backer and the button will pop right out. The plastic has close tolerance, so you must use a small instrument. I just did it again with a knife, but tore the rubber a little.
完成的
I had the same problem- it seems to the thing with this unit- after a couple years that little screw must vibrate loose. All tightened and working perferctly! Thank s people!!
完成的
添加一条评论
I had this same problem. Plugged in the power chord, blue light flickers, if I turn the chord a little bit it gets stable (makes contact) and then after a few seconds blue light off. I first thought the problem was just poor contact, which is a PROBLEM in my case because if flickers at first, but not the main problem as the light goes stable after good contact and them off after a few seconds.
As it turns out this model comes with a RED plastic protector, some king of plastic plugg to protect the DC socket. It's a small individual part you can put it in when you are not using and take out to use the trimmer.
When that plastic RED protector is plugged it protects agains water/humidity/etc AND the trimmer won't turn on. The same when you are charging, the trimmer won't work. So, I found that when you plug something in the DC socket there's a very small mechanical switch inside that prevents the trimmer to work.
So back to the beginning, the blue light goes off after a few seconds meaning the battery is fully charged. You plugg out the power chord and nothing. WHY? Because the mechanical switch is ON, in my case it was jammed, stuck in that position. I opened it all, did a bypass to that mechanical switch and VOILA, everything working normally.
So, what is my problem right now? I worked around the mechanical switch thing, but sometimes it does not charge, because the DC connector is bad, after me trying to clean it, end up forcing it, as I thought it was a calcination problem (not sure if this is the right term, calcination), I mean full of grey dust which prevents a good contact.
SO, now I need to replace the DC socket BUT don't know which type/size is it to look for it for example in ebay.
Does anyone now what type of DC SOCKET is it? Any reference? DC-003 maybe?
这个答案有帮助吗?
得分 2
3条评论:
Hello,
I'm having the same issue as you describe. How did you bypass the mechanical switch? It's so small, and the switch is encased inside the small grey plastic housing.
If you find the DC SOCKET, please let me know!
完成的
I found the DC socket, replaced it and the unit is now workding fine. No more blue light flickering.
Bought in ebay: "DC-003 3.5x1.3mm DC Power Jack Socket Connector 3-Pin Panel Mount Plug"
完成的
How did you remove the original socket and the re attach the new socket?
完成的
添加一条评论
I will chime in here with my experiences, in case they’re useful for anyone else:
  • I also have the Wahl 9818L, ie. “Wahl Lithium Ion+ Stainless Steel Trimmer”, with the hidden screw as shown and described above
  • I also began experiencing the “flickering blue light” / refuses-to-charge issue after a year or two of use
  • I ordered some replacement DC-003 sockets off of the internet, as suggested above
  • desoldering the original socket and soldering in a new one resolved the issue
  • after about another year, I accidentally dropped the trimmer and the issue returned
  • I still had some spare replacement DC-003 sockets, and soldering in another new one resolved the issue again
Thanks to all the contributors above for sharing their tips — I’m glad to be able to keep the trimmer in use for only the cost of a few cheap DC-003 replacement sockets!
这个答案有帮助吗?
得分 2
添加一条评论
Just use a skinny blade phillps head screw driver or something thin like a feeler gauge to pop
the external button out , its just a pressure fit. I think the external button itself is the most of the problem
with these . Its either misaligned in the case of always on or worn off on the actuator knub that hits
the actual switch is worn down.
The first picture doesn't seem to show a model 7818
这个答案有帮助吗?
得分 0
4条评论:
Just adding to the trail. Same problem as above with the bat. not charging (or intermittently). Once I had it apart (good directions above) I wiggled the cord into the unit and the light went on an off. The connection has 3 points soldered to the board and thought there might be a dry joint but could not be that lucky! I found the item through the ebay link above - about $4 Aussie. Will let you know how I go when the part is installed.
完成的
Hi did you replace this? I want to buy the DC socket but it’s stick to the green board. How to replace it? I know nothing of electronics but it sounds like others have done this.
完成的
My power button it's broken where Cain I find it?
完成的
Did we ever source a power button?
Mine seems to have just popped out and there doesn’t seem to be a good way to reinstall the thing.
完成的
添加一条评论
Looks to be the charging plug not making proper contact inside the charging receptacle. I am not sure how to get it to work properly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim Mikkelsen 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 109
过去 30 天: 425
总计 47,366
